Original Tip Date: Nov. 21, 2003
Can't see all of your reference tools?
| MicroStation V8 - If you've minimized the reference dialog so much that you can't see the tool icons, turn on Auto Arrange Icons from the Settings menu. That's it. That's all. |
AskInga Tip #360
