Original Tip Date: Oct. 2, 2003
| Number of clip masks allowed | |
| Barry Bentley wrote in v8.general: "You can have up to 200 clip shapes (if 1 is used for the boundary, the other 199 can be used for clip masks). They can total up to 2500 points. A clip rectangle takes 5 points, because the first and last point is the same. One point is used to separate each void, too. That compares to a total of 101 vertices in MS/J and earlier versions." | |
AskInga Tip #302
