Original Tip Date: Jun 14, 2002
Reference settings in Saved Views
| MicroStation V8 - Wished saved views would also save the display status of your attached reference files? Well they do now! Just be sure to enable the Reference Settings switch in the Saved Views dialog. |
AskInga Tip #174
