Clip a reference with an element not a fence
AskInga logo
Original Tip Date: Jun 14, 2002
MicroStation V8 - Need the ability to modify a clip boundary? Or do you want to clip/mask several files at once? If so, use a closed element in your active design to define the clip boundary. Just be sure to adjust the settings of Clip Reference to Method=Element.
AskInga Tip #192
