Original Tip Date: Jun 14, 2002
Select all levels or all references
MicroStation V8 - Need to select all the levels in the Level Display or Level Manager dialogs?
Use Ctrl+A
(Thanks Gino!)
By the way, you can use this method to select all references in the Reference dialog as well! |
AskInga Tip #199
