Original Tip Date: May 31, 2006
| Assign rasters to a level | |
| With thanks to Bentley's Rudi Wells for pointing this new MicroStation V8 XM Edition feature out! When attaching a raster, it is automatically assigned to the active level, but you can change this via the Workspace > Preferences dialog. Just navigate to the Raster Manager category and change the level in the Default Raster Attributes section. Of course you can also change the assigned level via the Raster Manager dialog as shown in the clip below. Note that raster attachments are now treated as standard elements with regard to level-related operations, such as display, freeze, lock, plot and viewport freeze. | |
AskInga Tip #648
