Original Tip Date: Jun 14, 2002
| Using AccuSnap when placing a fence | |
| MicroStation V8 - Ever notice how you have to issue a manual tentative point when placing a fence 'cause AccuSnap is disabled? Well, try this, press the CTRL + SHIFT and bingo, it's baaaack! Thanks to Bentley's Phil Chouinard for this tip! Related Tip: Option To Enable AccuSnap For Fence Placement | |
AskInga Tip #207
