Original Tip Date: Nov 20, 2007
| Reorder the Task list | |
| To place your custom tasks below the delivered tasks, set MS_GUIDGNLIBLIST to: $(MSDIR)ustation.dgnlib;PathToYourDGNLIB When MicroStation is started it will process the files found by this variable in the order listed. With thanks to Bill Steinbock [Bentley] for sharing this on the discussion groups. Note: The task menu shown below can be displayed by using the F2 function key. | |
AskInga Tip #751
