Original Tip Date: Sep 19, 2007
| Prevent tool boxes from changing orientation when moving | |
| To prevent tool boxes from changing orientation or "auto-docking" when moving between application windows, simply hold down the CTRL key while moving them. Note: This is in reference to having two application windows open via Workspace > Preferences > Operation With thanks to Ron Jones for sharing this on the discussion groups. | |
AskInga Tip #739
