Original Tip Date: Jun 12, 2007
| Restore deleted menu items in MicroStation V8 XM Edition | |
| In MicroStation V8 XM Edition only additions and deletions to the baseline MicroStation menu are stored in the dgnlib. So, when you delete a menu, or menu item, you are really adding an entry requesting that the baseline menu or menu item be removed. To restore, or remove the delete request just select delete again. This time delete means to delete the original delete request. Note that in the Customize dialog, deleted menu items are shown in red while additions are shown in green. With thanks to Bill Steinbock for providing this explanation. Related Tip: Restore Menu Bar Customizations | |
AskInga Tip #721
