Original Tip Date: Apr 5, 2007
| Miss the old Main tool frame in MicroStation V8 XM Edition? | |
| If you prefer to work with the old style Main tool frame, simply do a CTRL+T to get to the Tool Boxes dialog and enable Main Classic. You can also use this keyin to do the same thing: dialog toolbox mainclassic | |
AskInga Tip #710
