Original Tip Date: Dec 6, 2006
| Small triangles mysteriously showing up in your views? | |
| With thanks to Brien Bastings for sharing the following information about MicroStation V8 XM Edition SELECT Update #1: If it's determined that an element is too small to warrant displaying with all it's detail, MicroStation will display a simplified representation with either a small triangle or tiny dot. You can see this quite clearly in the clip below - especially once the view has been fitted. | |
AskInga Tip #691
