Customize the width of the level picker
AskInga logo
Original Tip Date: Jun 2, 2006
Bentley's very own Gino Cortesi shares this tip:
To adjust the width of the level picker in MicroStation V8 XM Edition, add the following variable to your configuration:
MS_LEVEL_PICKER_WIDTH = x where x specifies the width in screen pixels.
Note: Editing or adding this variable requires a restart.
Related Link:
Change How Levels Are Displayed In The Attributes Dialog
AskInga Tip #653
