Original Tip Date: Jun 1, 2006
| Press and hold the reset for pop-up menu | |
| So, in MicroStation V8 XM Edition you'll find a sweet little enhancement for the Reset mouse button. If you press and release ("click") the button, it's just a normal MicroStation Reset. But, if you click and hold it, you'll be presented with a pop-up menu with a ton of functionality. You can change how the button responds to the picking, clicking, holding, and poking via Workspace > Preferences > Input > Reset Pop-up Menu. Related Tip: [[Element Selection missing from Reset pop-up menu?]] | |
AskInga Tip #651
