Original Tip Date: Jan. 12, 2006
| Left-handers unite! Change position mapping to your side | |
| You a left-hander stuck in a right-hander world? If so, then go to Workspace > Preferences > Position Mapping and click on the button marked Left Handed. In doing so, the positional mapping will be changed to the right side of the keyboard. | |
Askinga Tip #604
