Original Tip Date: Feb 23, 2005
Keyin to toggle dialogs on and off | |
Here's a great shortcut from Bentley's Rudi Wells! If you want to toggle open dialogs from your view temporarily, put this on a function key: dmsg sinkall toggle Works with many dialogs including: Cell Maintenance, References, Tags, Level Display, Level Manager, and the Raster Manager. For additional information about the dmsg keyin, refer to the following article: Using keyins to toggle dialogs and toolboxes! Related Tip: Improve On The Dmsg Sinkall Toggle Command | |
AskInga Tip #491
