Original Tip Date: Nov. 5, 2003
| Improved dynamics in MicroStation v8.5 will rock you! | |
| Hey, Hey, Hey,....did ya hear what Ray had to say? "Drag a slab in an orthographic view. Rather than the overlapping lines disappearing, you can actually see them!!! This is true in all cases where the dynamics used to disappear when lines overlapped." | |
AskInga Tip #342
