Remove send viecon plot from the file menu
Original Tip Date: Jul. 3, 2003
Remove
Send Viecon Plot
from the
File
menu
MicroStation V7 - To remove the
Send Viecon Plot
option from the
File
menu, locate and rename/move
vplot.*
Thank you Phil!
AskInga Tip #296
