Original Tip Date: Oct. 31, 2002
| Load different function key menus | |
| Thanks to Sean Forward and Cameron Bauer for this little ripper. You can load different function key menus with the following keyin: AM=(menu name).MNU,FK Just ensure that that the menu files (*.mnu) are in the same folder that's being pointed to by the MS_FKEYMNU configuration variable. Dave Preston adds: And of course you can set up one of your keys to load another function key menu. That way you can toggle between them or cycle through a number of them - of course with a message to say which one is loaded. Thanks guys! | |
AskInga Tip #228
