Original Tip Date: Oct. 31, 2002
| Toggle the display of the ACS Triad | |
| Now here's something great from Shawn Foster: MicroStation V8 - A simple solution to turning the ACS Triad on and off *without* having to open the View Attributes dialog is this keyin: set acsdisplay toggle;selview all;update all | |
AskInga Tip #231
