Original Tip Date: Apr 12, 2002
| Maximize real estate when drawing with ByLevel definitions | |
| MicroStation V8 - If your drafting standard require you to use "ByLevel" definitions - then fix up the Attributes tool bar to your advantage! All you got to do is set the Colour, Style and Weight pickers to ByLevel and then disabling thier display by doing a right-click. The end result is cool and takes up less real-estate! | |
AskInga Tip #149
