Original Tip Date: Feb 16, 2001
| Dialog box ID's | |
| To find out what the ID is for any dialog / tool box, use this set of keyins: Dmsg dialogdebug on Open a tool box and note the ID number in the message box. It will normally appear as 'dbox'=-XXX When you're done, stop the dialog debugger with the keyin: Dmsg dialogdebug off You can then use the following keyins: To close a dialog from a macro: MbeSendKeyin "dmsg closedialog -46" where 46 is the ID for the dialog box. To close a dialog from MicroStation: dmsg closedialog -46 where 46 is the ID for the dialog box. To close a dialog from an application, use: MbeSendKeyin "dmsg closedialog GEOGRAPH 5046" Note that the application must be started. | |
AskInga Tip #70
