Original Article Date: Aug 10, 2005
Here's a nifty little macro from Mike that eliminates the need to memorize the keyins needed to verify and repair a design file.
Download 257.zip and extract FixFile.mvba from the zip file.
Place the mvba in the folder pointed to by MS_VBASEARCHDIRECTORIES.
Keyin vba load fixfile to load the project, or...
Configure MS_VBAAUTOLOADPROJECTS to automatically load the mvba project upon startup.
Keyin vba run fixit to run the macro, or....
Place the keyin on a function key or custom button for quick and easy access.
This program is supplied as is. AskInga, Bentley Systems Inc., and the author of the program assumes no liability for damages direct, indirect, or consequential, which may result from the use of this program. Use this program at your own risk.
AskInga Article #257
