Original Tip Date: Jun 22, 2004
| Macros to quickly change the view window background colour | |
| Rudi Wells was kind enough to post these two macros on the V7.General discussion boards. They work in both V7 and V8. To change the view background to white: Sub Main MbeSendCommand "MDL SILENTLOAD USERPREF" MbeSetAppVariable "USERPREF", "savePrefs.extFlags.invertBackground", 0& MbeSendCommand "MBE1 CLOSEMODAL OK" End Sub To change the view background to black: Sub Main MbeSendCommand "MDL SILENTLOAD USERPREF" MbeSetAppVariable "USERPREF", "savePrefs.extFlags.invertBackground", 1& MbeSendCommand "MBE1 CLOSEMODAL OK" End Sub | |
AskInga Tip #449
