Original Tip Date: Mar 26, 2007
| Used vs Bold in the Level Manager and Level Display dialogs | |
| Both the Level Manager and Level Display dialogs give you feedback regarding the usage of a level. For example, if the used column displays a dot, the level is being used in the active model. If the level's name is bolded, but there's no dot in the Used column, then it's being used in the file but not in the active model. Finally, if the level name is not bold, the level exists in the file, but is not being used in any model. | |
AskInga TIp #706
