Original Tip Date: Jun 6, 2006
| Force attributes to go to ByLevel | |
| Here's a great tip from Hilton Quinn. To force the active attributes to go to ByLevel, simply add the following to your PCF or UCF file: MS_DGNAPPS < synchbylevel You'll notice it's effect when changing the active level or when re-opening the file. | |
AskInga Tip #655
