Original Tip Date: May 3, 2005
| Freeze levels with a keyin | |
| To freeze levels using a keyin, use this: level set frozen [on|off|toggle] file:file-spec level-spec For example, to toggle the frozen state of 10_pipe in all files (including references) the keyin would be: level set frozen toggle file:all 10_pipe With thanks to CadAd for posting this on the discussion groups! | |
AskInga Tip #535
