Original Tip Date: Jan 10, 2005
| Toggle the global display of level and level filters | |
| With many thanks to Kees van Prooijen for this tip! MicroStation V8 - Use level set display on|off|toggle keyin instead of on= and of= since it also supports reference levels! Note that this keyin is actually toggling the Global Display switch of the level rather than the view display switch. You can see this clearly in the Level Manager. (Thanks Greg!) A few examples of it's usage: Turn off all levels and filters in all files in the active view: level set display off file:all all;point ab Turn on levels in all files in the active view: level set display on file:all *;point ab Turn on a specific filter in all files in the active view: level set display on file:all [level spec];point ab So, for a filter called 1:2500, the keyin would be: level set display on file:all 1:2500;point ab See Also: Toggle The Global Display Of Levels | |
AskInga Tip #479
