Original Tip Date: Nov. 5, 2003
| Keyin to delete level contents | |
| In case you missed it, Deepak was over in v8.general the other day saying something about a keyin: There is keyin level element delete "level-name" that deletes all the elements on the specified level in the active model. It does not delete the level nor shared cell definitions. You can then execute the level purge key-in to finally delete the level." | |
AskInga Tip #345
