Original Tip Date: Oct. 31, 2002
| Resetting back to ByLevel Attributes | |
| Put this handy-dandy keyin on a function key: ACTIVE SYMBOLOGY BYLEVEL This will set all of your active element attributes to ByLevel and is particularly useful after drawing somthing without ByLevel attributes. With thanks to Mark Mates for sharing this on the V8 Newsgroup. | |
AskInga Tip #225
