Original Tip Date: Dec 31, 2002
| Control level display in the Level Manager | |
| MicroStation V8 - To turn levels on/off from the Level Manager, highlight the levels to change and simply poke the Global Display column. Note that this is different than turning the selected levels off from the Level Display dialog in that it turns it off in all views and in all models. Note, in older versions of V8, the column is named Display. Bentley's Gino Cortesi explains: In 8.1 we renamed this column in Level Manager from Display to Global Display to better communicate what it's changing. The original design was done to match the Display column in the Reference dialog, but was found to be a source of confusion. | |
AskInga Tip #195
