Original Tip Date: Feb 6, 2002
| Disable the creation of new levels | |
| Here's one for the administrators....in order to stop a user from creating and deleting levels in the design files, add the following line in your standards.cfg file: _USTN_CAPABILITY > -CAPABILITY_LEVELS_CREATE This is especially useful when you're driving levels from a level library. Note: In MicroStation V8.5 - 2004 Edition, the New Level icon will be dimmed to reflect the disabling of the ability to create a new level. | |
AskInga Tip #134
