Original Tip Date: Nov 6, 2001
| Keyin for turning on and off levels in MicroStation V8 | |
| To turn ON all the levels, use this keyin: ON=ALL and select the view. Similarily, to turn OFF the levels, use: OF=ALL Or, use ON=* and OF=* which do the same thing. To really turn these into smart keyins, stick them on a couple of function keys and change to read as follows: ON=*;SELVIEW ALL OF=*;SELVIEW ALL | |
AskInga Tip #127
