Original Tip Date: Feb. 16, 2001
| The Ninja Pick. | |
| MicroStation V7 - To turn off or on all levels in the View Levels dialog; use the Ninja Pick. Position your curser beside 63 (where you would find 64 - if it was labeled), hold the Shift down, then hold the left mouse button down and drag across to number 63. | |
AskInga Tip #27
