Original Tip Date: Sep 14, 2006
| Delete a point symbol from the line style resource file | |
| To delete a point symbol from a line style resource file, use the following keyin: DELETE SYMBOL name A couple of notes...a line style library must be active to use this tool, and a symbol being referenced by any point component can not be deleted. | |
AskInga Tip #670
