Original Tip Date: Mar. 29, 2006
| Annotation scale applied to line styles | |
| In MicroStation V8 XM Edition, every model can have a global line style scale factor that is applied to every line style within the model. The scale of line styles within a reference can be affected by the global line style scale of either the active model, the referenced model, both, or neither. A model's global line style scale factor can easily be set to be the same as the annotation scale factor. Related Link: Global Line Style Scale Setting | |
AskInga Tip #644
