Original Tip Date: Jun. 3, 2003
Change line style scale of references
To scale up or down custom line styles of an attached V8 reference do this:
- Set the Level Manager to Overrides
- Highlight the correct level from the reference attachment
- Set the Style column to the existing line style in the file
- Then right-click the level and go to Properties
- From the Style tab, go to the Overrides section and adjust the scale to suit.
- Finally, do a CTRL+B and turn on Level Symbology
![](https://bentleysystems.service-now.com/community?id=kb_article_view&sysparm_article=KB0113052)
AskInga Tip #290
