Original Article Date: Feb 17, 2001
Using MicroStation's batch plotting utility, you can compose and reuse job sets that identify design files to be plotted and the specifications that describe how they should be plotted.
Authors Note: This article has also appeared in the April 2000 issue of The MicroStation Manager magazine.
Using the new batch plotting utility, you can compose and reuse job sets that identify design files to be plotted and the specifications that describe how they should be plotted. BatchPlot is not a replacement for plot configuration files. It is simply a plotting utility that focuses on plotting multiple design files versus plotting the active design file.
Plot Specifications is a named group of instructions describing how to perform a certain step in the plotting process. They are stored outside of job sets so that they can easily be shared across sets. A job set is an ordered list of design files to be plotted, along with references to the plot specifications that control how they are plotted.
There are four types of plot specifications:
Managing Plot Specifications
The BatchPlot Specification Manager dialog box (Specifications > Manage) is used to create, copy, rename, and delete plot specifications and any changes or modifications made to the current specifications will be assigned to the current job set.
Creating a list of files to plot
Once the specifications have been set up, you can select the files to be plotted. This is done from the Edit > Add Files menu item or by simply dragging and dropping a suite of files from Windows Explorer into the BatchPlot dialog. Since BatchPlot will process the files in the order in which they appear in the dialog you may want to pre-sort them in Windows Explorer prior to adding them to the dialog. Then again, you can also rearrange the order of the files in the dialog by selecting them and using CTRL+U for "up" and CTRL+D for "down".
Saving the Job Set
You can save the current settings, which includes the plot specifications and the list of design files to plot, in an external file referred to as a Job Set. The Job Set file has an extension of .job and is written by default to the workspace/projects/examples/generic/out diretory.
Using Job Sets allows you to easily reassign specifications at any time making it easier to plot variations of the set. Named plot specifications are referenced by the job set and are stored in a separate specification file. This separation allows for the sharing of specifications among many job sets and simplifies maintenance. Changes to existing specifications and additions of new specifications are automatically available for use in all job sets and are also propagated to existing sets which reference them.
Files and directories
All user preferences are stored in the file ${MS_DATA}batchplt.rsc (...workspace/system/data/batchplt.rsc). The only preference saved is the name and location of the last job set file saved or opened.
All specifications are stored in the file ${_USTN_WSMOD}default/data/batchplt.spc (.../workspace/projects/batchplt.spc).
You can configure BatchPlot to use a different file by setting the configuration variable MS_BATCHPLT_SPECS to point to the desired file through Workspace > Configuration > Plotting >Batch Plot Specification.
The user controls the names and locations of job set files. By default, job set files are saved in the directory specified by the configuration variable MS_PLTFILES.
The default BatchPlot log file (written to record the status of the actual printing process) is MS_PLTFILES:batchplt.log (.../workspace/projects/examples/generic/out/batchplt.log).
Errors when using BatchPlot
When BatchPlot detects an error, it stops processing the plot boundary in the current design file, and then continues processing. Some of the more common errors include:
AskInga Article #55
