Original Tip Date: Feb 16, 2001
| Masking text on plots. | |
| MicroStation V7 - Change colour 232 in your colour table to RGB=255,255,255. This will / should plot white. Place a block or circle in your file and ensure that it's fill-type is opaque and colour is 232. Place your text on top of it. Then just turn on the fill display when creating a plot. | |
AskInga Tip #71
