Turn off the display of the active level
AskInga logo
Original Tip Date: Jun 14, 2002
Don't display your active level
MicroStation V8 - Did you ever want to turn off the active level in your other views? Weird as it may be, you can by disabling Display Active Level in all Views in the Workspace > Preferences dialog.
AskInga Tip #198
