Original Tip Date: Oct 22, 2004
| Extract measured distances from MicroStation | |
| With thanks to Karl Peterson for prompting this tip! To extract or copy measured distances from the Tool Settings box, simply... Highlight the Last Distance and copy it to the clipboard with CTRL+C or Right-Click > Copy. Then just paste it into the recieving application with CTRL+V or Edit > Paste. If you've done a whole schwack of measuring, you can extract all the distances from the Message Center... Just select them, do a CTRL+C, and paste into the recieving application with CTRL+V or Edit > Paste. | |
AskInga Tip #465
