Original Tip Date: Mar 14, 2007
| Customize action for MicroStation on the Web / Bentley Library button | |
| You can customize the look and feel of MicroStation XM's Bentley Library button by editing the content in ...\workspace\system\data\microstation-bentley-com.htm. For example, to re-direct it to a web-site of your choice you can add the following line within the HEAD section: META content="0; URL=http://www.YourWebSiteHere.com/" http-equiv=Refresh (Don't forget to embrace this line with the pointy brackets: < >) Of course, if you're fluent in HTML, you could also customize the page to to suit your needs. The same holds true for MicroStation V8's MicroStation on the Web button Related Tips" Keyin To Access A Website From MicroStation With thanks to Phil for sharing this on the discussion groups. | |
AskInga Tip #705
