Using the Expand Keyin
AskInga logo
Original Tip Date: Nov. 5, 2003
Using expand keyin and $
Gino wrote this in v8.general with his favorite crayola:
MicroStation V8.5 - expand keyin expands configuration variables in the key-in, then sends it to MicroStation.
The $ keyin is an alias for expand keyin.
For example:
expand keyin create cell $(basename(_dgnfile)
Attempts to create a cell using the name of the file.
$ create cell $(basename(_dgnfile))
Is the same as above.
The above keyins will only work when expandkeyin.ma is loaded.
AskInga Tip #339
