Original Tip Date: Nov 30, 2006
Phantom model in your file?
If your Model dialog is showing models that don't exist in the file, use the keyin model reindex to clean the file up.
With thanks to Josh Schifter for sharing this on the discussion groups. |
AskInga Tip #687
