Original Tip Date: Apr. 30, 2001
| Remember that nifty overview command? | |
Well, this command has long since disappeared off of MicroStation's interface - but if you're a SELECT subscriber, you can get both V7 and V8 versions from http://microstation.bentley.com/files/motw/resources/utilities/V8MDLExamples.zip
AskInga Tip #94
