Original Article Date: Aug 15, 2007
With thanks to Rommel Tan for contributing this macro that allows to navigate your design files by using a Batch Plot Job File rather than Windows Explorer.
Download 315.zip and extract the contents to the folder pointed to by MS_MACRO.
This macro requires that you have a Batch Plot Job File available. Once loaded, it reads the contents of the selected job file and presents the files in a list box for opening. Additional details can be found in the help text file located in the zip file.
This program is supplied as is. AskInga, Bentley Systems Inc., and the author of the program assumes no liability for damages direct, indirect, or consequential, which may result from the use of this program. Use this program at your own risk.
AskInga Article #315
