Original Tip Date: Feb 26, 2002
Quick and easy way to edit level names!
MicroStation V7 - Rather than changing level names via the Level Names dialog, try this!
- Open the Level Names dialog
- Do a File > Save and enter a name. You have just exported your exiting level names to an external text file with the extension of LVL. This file is also referred to as a Level Structure file
- Open the LVL file with any text editor and change the names as you wish. Be sure to maintain the columns as they are.
- Back in MicroStation, and still in the Level Names dialog, go File > Open and select the modified LVL file.
Ta-Da!
AskInga Tip #137
