Original Tip Date: Jun. 18 2003
How to convert a MicroStaiton /J 3D cell library to 2D | |
From within a MicroStation /J design file which has the 3D cell library attached: File > Export > 2D > Conversion Option > Attached Cell Library > Select directory and enter name of new cell library file > OK This will create a new 2D cell libary using the top view of the original 3D cells | |
AskInga Tip #293
