Original Tip Date: Feb 27, 2002
| Create cells by keyin | |
| To create a graphic cell, ensure you've defined the origin and keyin: CC=Cell_Name,Description For example: CC=GVAL,GATE VALVE To create a point cell, change the keyin to read: CC=Cell_Name,Description,P For example: CC=GVAL,GATE VALVE,P | |
AskInga Tip #139
