In MicroStation V8i, the Point Distance keyin (DI=Distance, Angle) keyin recognizes the direction of north while previous versions did not. Take the following example.
From the General/Examples workspace, open Import-Export.dgn and navigate to the 2D Site Data model. Review the True North Direction, or degrees from the X axis, by looking at the Solar Position tab of the Light Manager and note that it's set to -40.0 as shown:
Choose the Place Line tool, enter a datapoint anywhere and then keyin DI=85,30 followed by a reset to complete. The resulting line is similar in orientation to the red one shown in the graphic below.
If the same file is opened in a previous version of MicroStation, the line would be drawn with the following orientation:
Changes to the DI= keyin
With thanks to Bentley's Tim Hickman for this tidbit.
